Flat gas Tanks
- ToddW
Flat gas Tanks
Where's the best place to order the flat gas tanks from ?
- ToddW
Thanks, I'd like to see the pics. I have a couple mounts coming, and velcro to use for now.ATV'er wrote:You can buy mounts or what I use is some small dog colars and I pull them tight then push the pin through the colar. It works pretty good. I can take a pic if needed.ToddW wrote:Thanks!
They are on the way.
Now to make my mount.
My future plan is to build a mount/storage for them off the back of the quad. That way I can store 2 off the back against the quad, and have my pack in the front or in the back. This would also give me the option to take a 3rd tank on the front for camping trip, or SAR missions.
Also my front springs are already shot from plowing, and carrying around fuel up front would probably prompt that to happen again sooner than later.
- ToddW
Sounds like a great combo.ATV'er wrote:Ken I are both running the polaris HD springs in the front and the epi HD springs in the rear. It make a big difference. The stock springs get soft after a while. Plus the HD springs add a lot of ground clearence.
Got the part#s by chance and best place to purchase ???
- ATV'er
Here is the link for the rear springs. Just have to find your year and what engine you have.
https://www.erlandsonperformance.com/mm ... _Code=susp
Here is the front springs.
http://www.purepolaris.com/Detail.aspx? ... GACatalog)
- ToddW
Thanks much!ATV'er wrote:Here is the link for the rear springs. Just have to find your year and what engine you have.
- ToddW
I talked to Jason @ RotoPax and I`m getting some of thoseThe Modfather wrote:Regarding the flat packs - take some time and research the Kolpin flat packs vs. the Rotopax. The new style Kolpins have a reputation for leaking after a very short while. I have no experience with the new style Kolpins, just the Rotopax.
I did read a few places about ppl complaining of the Kolphins.
- RenoDeano
Flat Gas Tanks
Have been using the industrial grade type velcro securing devices sent with the tanks for 3 years, with no problem. I put a half moon heavy card board cut out under the flat pack.
"A physicist's theories are worthless unless he can explain them to the barmaid at the local pub." --Rutherford
Outlanders Max XTs 400 and 800 (with tracks)
http://picasaweb.google.com/104730725462657207876
Users browsing this forum: No registered users and 195 guests
