I bought the PDF manual on eBay a few months ago. Quite nice to have for quick reference.The Modfather wrote:Oh, i was asking cuz I have a few PDF manuals and happen to have one for the BF750 - was going to pass it along. In there, it should show you how to remove the primary sheave.
edit: and measure the deflection of the belt to let you know if it's too loose or too tight.
CVT Belt Replacement (Kawi Brute Force 750i)
- BruteForce
- Elheffe24
Hey BF your belt should not be tight at all you should be able to put a straight edge from the driven pully to the primary and with very little effort push down on the belt to get about 1 inch of deflection. Also from my experience stick with the Kawi belts the aftermarket stuff is junk. To get the primary clutch off you need a primary puller about 40.00 if you need one I can send you mine on loan. I am in a hurry this morning to get off to work but here is a good link on belt tightening deflection settings for the brute.
http://www.highlifter.com/forum/How_To_ ... 669/tm.htm
Good luck
Good luck
2006 Brute Force 750, HMF Utility, Copperhead CDI, 26" Bighorns,
Users browsing this forum: No registered users and 11 guests
