CVT Belt Replacement (Kawi Brute Force 750i)
- BruteForce
Help!
I just pulled the CVT cover off to replace my belt and I'm finding there's old belt shrapnel still wrapped around the spline on the rear most pulley. I've been unable to budge the bolt to remove that pulley (turns the crank) to remove the old belt components. Here are a few photos to illustrate where I'm at. Any advice appreciated.
What was left of the old belt
- BruteForce
Got it off (finally). Damned near threw my back out trying to put as much torque on that bolt as humanly possible. I used another wrench in the holder hole to keep the pulley from moving.
Once I had the pulley off, I had to pry under the spring to force the belt remnants out.
New belt installed, switch flipped back to on, wires adjusted.. Bingo!
There's NO WAY I could have serviced this in the field. The amount of tools I required wouldn't be possible to take with.
- Aka: Fishoil
- BruteForce
- BruteForce
You can just slide it over the driven provided you turn the pulley to help it along.Atila wrote:How much trouble is it to change normally. I always carry a spare when i go riding but never took the time to really check whats needed to change it. Do you really need to remove the drums or can you slide it over the edge?
I had to take off the pulley(s) to remove the belt shrapnel that was stuck in the spring of the driven pulley.
- BruteForce
So I ordered yet another CVT Clutch Belt (so I could have a spare) and put the new one on today. The new and old (~150 miles on it) are the same exact Goodyear Gator Sport belts (same part number, etc).
The old one had quite a bit of give to it compared to after I installed the new one.
What's really odd is now that the new one is in place, sitting in gear, the ATV will move at 1-2mph (same in reverse). I have to put on quite a bit of brake to get to a complete stop and it takes a little "jiggling" to get it into neutral.
Is this normal with a brand new belt or is there some other issue?
Now, except for back & forth riding in my driveway (about 25' back and forth), I've not yet ridden the machine to break in the belt.
Idle too high?
- BruteForce
Nope. From what I've read thus far, it would appear the new belt is just a bit snug and that it should "break-in" shortly after I begin riding.Ken wrote:Idle too high?
As it stands, after putting the new belt on, the clutch engages and the ATV starts driving (1-2mph) by itself in D and R and shifting into N is somewhat tricky.
- BruteForce
Yes, I have a service manual. As of yet, I've been unable to get the pulley (to the right of the driven) off the ATV. I can remove the bolt, but I haven't figure out how to remove the pulley.The Modfather wrote:Sounds to me like you need to shim the sheave as the belt appears to be grabbing when it shouldn't
edit: Do you have a manual for your bike?
Why?
What did you do with the left over parts?BruteForce wrote:So I ordered yet another CVT Clutch Belt (so I could have a spare) and put the new one on today. The new and old (~150 miles on it) are the same exact Goodyear Gator Sport belts (same part number, etc).
Sounds like you might have the wrong belt or a shim was left out.
Goodyear belt? Why? I would go stock belt.
I think the goodyear has Kevlar right? I know of Kevlar belt on Polaris cutting in to the Shives..
- BruteForce
No extra parts. I kept the "old" belt because I needed a spare. Are for why on the Goodyear belt, it was the only one offered by rockymountainatv.com for this machine. I've used them before, but never experienced this "walking" issue.MrBill wrote:What did you do with the left over parts?BruteForce wrote:So I ordered yet another CVT Clutch Belt (so I could have a spare) and put the new one on today. The new and old (~150 miles on it) are the same exact Goodyear Gator Sport belts (same part number, etc).
Users browsing this forum: No registered users and 105 guests
