Larry I assume you mean to ajust each side evenly to get the correct almnt..........is this correct??? don't try to get all the ajustment on one side??check is side to side alignment.
Exactly Dave, start with your bars in a neutral position and do a little on each side. Ideally you want the toe set and each side, axle center to center, the same. If you need any help setting the toe my winch is availableDAVE wrote:Larry I assume you mean to ajust each side evenly to get the correct almnt..........is this correct??? don't try to get all the ajustment on one side??
Dave, do you know what the diameter of the new rods?DAVE wrote:just finished with the alinement,,,,,,,,,,,worked exelent with the string set up, thanks MrBill and Larry...........
Users browsing this forum: No registered users and 51 guests
