What is a "snatch block"
- Wildhorse800
Getting too off topic on other thread....seriously...I don't know or I know it by a different name...
These guys needed one
http://www.atvobsession.com/video/snatchblock.wmv
And these guys lost one.
http://www.atvobsession.com/video/snatchless.wmv
A snatch block doubles your pulling power. You've seen a block for lifting a piano or heavy safe. Same principle.
Imagine this.....You are trying to pull your quad that is stuck in deep snow or mud. The quad weighs 1000lbs...but with the suction from the mud, it now weighs the equivalent of 3000 lbs. Too much for your winch.
So, with a snatch block....you would have the cable come OUT of your quad and toward a tree. If you attached right now, you'd be trying to pull all 3000lbs. No good. But...you have a snatch block. So you wrap a strap around the tree, and attach the snatch block. You then loop your cable through the snatch block and send the cable back toward your quad and attach. So you're winch cable is now coming out, to the snatch block and back to the quad. There are 2 cables, not one. Right?
Well....the snatch block halves the weight on each line.....so one line is pulling 1500lbs from the winch to the snatch block (that's the part the winch cares about) and 1500lbs from the snatch block to the quad. (the winch doesn't know about that). So now your winch is only pulling 1500lbs...which is doable for most winches.
If you added another snatch block at your quad and went back to the tree, each cable would be pulling 1000lbs. If you added a 3rd, at the tree and went back to the quad....You now pull it out with a chinese winch! Each cable was now pulling 750 lbs....the winch only cares about the 1st cable.
That help?
It also works great for pulling sideways....
You can see the cable to the snatch block to pull my quad back over.
That help?
- Wildhorse800
Wildhorse800 wrote:Seen them before, just didn't know what they were called.
Good explanation. Could just use a big 'ole pulley!(less friction)
Snatch blocks have a wheel with a bearing...there's no friction.
- Wildhorse800
Another way to understand it is to use good ole F=ma from physics.
Imagine Ken's case with the snatch block anchored to a tree, and your winch line going through it and back to your quad. Throughout the time you are pulling, the snatch block doesn't accelerate away like a space ship. This means that the total force (F) must be zero since the acceleration (a) is zero.
As you pull on the snatch block, the tree pulls on it too, so the total forces (vector-wise) are equal. There is only 1 line going to the tree, but 2 lines (each half of your winch cable) going back to your quad. Since those lines are going in the opposite direction as the tree, each line to your quad must be carrying half the force.
So in Ken's case, with a 3000 lb total pull (from the tree to the block) your winch sees 1500 lb and the quad sees the other 1500 lb. Total force (vector-wise): 3000 - 1500 - 1500 = 0. Zero is good, the snatch block stays where it is supposed to be.
Now just for fun... have someone cut the line to the tree while you're winching. If you know the mass (m) of the block, you can calculate how fast that ole block is going to instantaneously accelerate back at you: a = F/m. My guess is you'll be dead long before getting the math worked out.
That's my vote.GrizzlyGuy wrote:My guess is you'll be dead long before getting the math worked out.
Try this little how-to: http://www.4wdandsportutility.com/tech/ ... to_07.htmlWildhorse800 wrote:I'm gonna have to see one up close to get a better idea of how it works...
- Wildhorse800
There we go. Like I said, it is basically a pully system. The more pullies, the easier the pull.
Definitely need one of them as they look pretty bullet-proof.
I am thinking I can home make my own for @ $20 instead of payng out $70.
- traildad
As long as you remember quality countsWildhorse800 wrote:There we go. Like I said, it is basically a pully system. The more pullies, the easier the pull.
Now just for fun... have someone cut the line to the tree(or break the pulley) while you're winching. If you know the mass (m) of the block, you can calculate how fast that ole block is going to instantaneously accelerate back at you: a = F/m. My guess is you'll be dead long before getting the math worked out.
05 Yamaha Kodiak 450, Mine
05 Yamaha Kodiak 450, Wife's
We love to go Trail Riding and "ATV Backpacking"
- Wildhorse800
oh my.....
This is from Montana Jacks...the best high quality ATV products website.
http://www.montanajacks.com/index.asp?P ... &ProdID=80
Or for $20 more...get 2 U Shackles, 2 Tree savers and a storage bag.
http://www.montanajacks.com/index.asp?P ... ProdID=940
Users browsing this forum: No registered users and 32 guests
