What to carry along???
- Wildhorse800
Gonna be placing an order from RMATV.
Looking to fill the cargo box with trail necessary items, i.e. tow strap,jumper cables first aid, etc.
What do you all carry? Any ideas will do...
Tow strap, snatch block ( ), tire repair stuff (patches, plugs, air source, vavle stems), rachet strap (you'd be surprised how handy these are), various nuts and bolts, tool kit (rachets, sockets, pliers, screwdrivers), and I usually carry a couple of spare spark plugs.
I also carry things like a lighter, couple of energy bars and first aid kit for emergencies.
all of the above, and:
Extension cable for the winch
tree saver strap
D-rings (to connect things together)
folding hand saw
flashlight
plastic garbage bag(s)
small towel
lug nut wrench (just a socket and handle, actually)
tree saver strap
folding hand saw
flashlight
small towel
Backpacking gear works great for alot of atv' stuff
i carry petty much all the same as kendo and Hemigrey
Coat! you never know lighter Backpacking stove always
fuel canister for backpacking stove you can pic them up at walmart
for about 25 bucks not as great as a jetboil but will boil 2full cups of water
in 3 minutes to a rapid boil
I have the slime air compressor that montana jacks atv outpost sells works great and has multiple power options. via battery or 12 volt plug.
shovle 97% of the time small backpacking lanturn that has emergcy flash beacon mode on it. odds and in's i guess usaly i will take extra socks if there is lots of water crossings and maybe extra shoes
Powertank and Plug Kit because you never know when someone will flat!
A fire extinguisher because you never know when someone will have gas pour out of their quad while winching up a cliff!
A first Aid Kit because you never know when someone will fly off of a cliff, roll, and fracture a femur!
A satellite phone, because anything can happen and it usually does just outside of cell coverage.
I forgot about under the seat, where this weekend I found a survival blanket, a poncho, a can of Slime and an inflator. I decided to add a small plastic tarp - in case of rain, something good for just one use.
I try to think about what would happen if I had to overnight even tho I just do day rides in the summer. It gets darned cold at night, even when the days are warm. And - get drenched in a t-storm and things could be really miserable.
Without any problem. The tank pressure for the liquid CO2 is around 800 psi, with the regulator you can get up to 150 psi to the tire.roon101 wrote:will that rebead a tire.
if so that is awsome set.
How do you get that little tank refilled? Just like getting any CO2 tank plumbed up?oldtrucks wrote:Without any problem. The tank pressure for the liquid CO2 is around 800 psi, with the regulator you can get up to 150 psi to the tire.roon101 wrote:will that rebead a tire.
The 20 ounce cylinder uses a pin valve like most paintball tanks. Most paintball stores have filling available and it's about $3. If you go with a larger tank like a 2 1/2 lb bottle then you might have to take it to a fire extinguisher shop for filling.The Modfather wrote:How do you get that little tank refilled? Just like getting any CO2 tank plumbed up?
- BruteForce
I carry enough to allow me to survive 2-3 days in the wild.
- First Aid kit (bandages, gauze, ointment, etc)
- Water purifying bottle (filter)
- Axe
- Shovel
- Extra 50' winch cable
- Hand saw
- Machete
- Cooking stuff (backpack stove, fuel, backpack pot, etc)
- Dehydrated food (standard Cabelas/MRE stuff)
- Fire starting stuff (matches, lighter, magnesium block)
- Extra box 9mm ammo
- Water (2-3 bottles + 100 ounces in CamelBak)
- Compass (and extra lithium batteries for GPSr & SPOT)
- Emergency Whistle
- FRS/GSRM Radio
- SPOT
- Tarp (I've had to use this already for an emergency shelter)
I carry a ton of stuff with me, but then I'm generally 50+ miles away from my vehicle and most of civilization.
- Axe
- Shovel
- Hand saw
- Machete
- Emergency Whistle
- FRS/GSRM Radio
- SPOT
2013 Sportsman XP 850 (Browning Edition) FI/EPS/LE
2005 & 2008 Kawasaki Brute Force 750i
Rider has ferocious attitude!
My blog site: http://utahbruteforce.com
Do you just throw these bullets, or is there a gun included.BruteForce wrote:Extra box 9mm ammo
Sorry couldn't resist.
Users browsing this forum: No registered users and 26 guests
