underbody armor
underbody armor
I am going to build some underbody skid plates for my quad here this weekend and next. I am not sure what type of metal I should get, or where to get it?
I was thinking about going to the local sign post and taking the sign. . . was in reality looking for some light weight, but strong metal, I think Larry and jack made some for their quads. . . any info would be greeatn
Remember when they used to make things out of toothpicks?
or.... What were those snap together blocks called?
or.... Can you say lincoln logs.... Ya see... it all relative. When you own a boat anchor..... Nobody cares.
God.... I killed you AGAIN..... life is sweet.
Leave it to Terry to give a smart ass answer. . . I guess that just means he is jealous that my rig will soon be in a state that will make his look like a kids toy. . .Mr. Miyagi wrote:Remember when they used to make things out of toothpicks?
Email Jack...I think he uses 3/8 Steel....but not sure.
You're up early...it's 11:15PM on Wednesday here.
Will have to email him. I think I can find his email lurking around my inbox somewhere. . .Ken wrote:Email Jack...I think he uses 3/8 Steel....but not sure.
Don't do that...... It will double the weight of your quad..... lol.I think he uses 3/8 Steel....
BTW - I think it's 3/16".
Where would you get this type of metal at? both 3/8 and 3/16 seems like a thick metal. would think that 1/8 would be more realistic, but then again I drive a honda, what do I know. . . NOT. . .Mr. Miyagi wrote:
- ACLakey
I would highly reccomend UHMW. Here is a post I made from another board.
Has anybody used UHMW to create skid plates and stick stoppers yet? I used to work for a Mechanical/Manufacture engineering firm and we used this material for many applications. It is light, STRONG , Very abrasion resistant and is very slick. It would make the perfect skid plate material epically for those who love rock hounding. You can machine and mill it just like metal.
Here is some information of it.
UHMW This Ultra High Molecular Weight (UHMW) Polyethylene bar has exceptionally high abrasion and impact resistance properties. It will outwear all other materials, including metals, nylons, urethanes, and fluoroplastics. In corrosion resistance, it has the same qualities of other polyethylene plastics. The working temperature range is from -60 to 200 deg F. Because it resists wear, friction and corrosion, it cuts maintenance costs, energy consumption, and extends equipment life. Applications include guide rails, wear plates, rollers, conveyor augers, bin and hopper lines, chutes, bearings, bushings and gears. Its properties include: low coefficient of friction, self-lubrication, non-adherent surface, FDA and USDA concurrence for contact with foods, drugs, etc.
Anybody used it for this type of application yet?
There isn't a metal made that would work as good as UHMW for this type of application.
Andrew
Andrew
Where would you get this type of metal? would you cut it with a plasma cutter or with a pair of metal snips? What about the cost. . . ?Junfan wrote:I would highly reccomend UHMW. Here is a post I made from another board.
Andrew
- ACLakey
UHMW This Ultra High Molecular Weight (UHMW) Polyethylene...yes it is a plastic. You can machine it just like metal, ie mill, drill, tap, turn on a lathe ect. Like stated above if you heat it you can bend it into just about any shape. When it cools the bend is set. It is VERY impact and abrasion resistant and is also self lubricating. As the material wears it gets smoother and smoother. It has a very low coefficient of friction, meaning it is very slick stuff and will slide right off rocks. It is the material of choice to line the bottom of drift boats because of it’s properties. It is truly great stuff and is the perfect material to use for this application.
I used to work at a Mechanical/Manufacturing engineering firm that makes machinery for the wood products industry. We used UHMW for applications ranging from bash plates, wear surfaces, bearings and bushings, gears you name it. We purchased it through our local metal supplier. Check to see if they will order it for you, if not do an internet search for a dealer. It comes in just about any form and color you could imagine. You can get bars, tubes, blocks, sheets and extrusion. A sheet of UHMW weighs about the same as a sheet of plywood of equal thickness, so it is a relatively light material. I think you could likely pick up a 4’x 8’ sheet of ¼” UHMW in whatever color for around $120. That would be enough to make a skid plate and stick stoppers. A little spendy, but it is far superior to any metal out there.
I hope this helps.
Andrew
I hope this helps.
Andrew
- RobG
I love the sound of that UHMW stuff... I might pick up a sheet of it and cut some skidplates out of it. Any idea if you can get the stuff in Reno?
And as Lizard pointed out, PRM makes killer skidplates. I had 'em on my Rincon and the suckers were darn near bulletproof. Almost 1/4" think, NOTHING would dent them. They held up 100x better than the Yamaha and Highlifter piece of crap skids I have on my Grizzly.
Rob
Rob
'08 Polaris Outlaw 525 S
'08 Polaris Outlaw 525 IRS
'02 Yamaha Grizzly 660
'05 Arctic Cat M7 153
'05 Dodge RAM 3500 QC 4x4 6sp
I'd buy 7000 rolls of aluminum foil...... and start wrapping that puppy.Where would you get this type of metal at?
We'll change your name to: Bubble Boy of the Rubicon......
Users browsing this forum: No registered users and 47 guests
