heelclicker clutch for 06 800
- extreme atv rider
ok well i've got 170 miles on 800 now i've burnt two belts playin in mud and hill climbs mudzilla's great for traction not good for stock clutch set up.
i went to heel clicker web site but not listed kit for 06 got one for 05 but is it the same? any help will be great
05 800 and 06 800 are the same... you should chek out EPI they have some good kits for bigger tires...http://www.erlandsonperformance.com/new/ATV-shop.php
Re: heelclicker clutch for 06 800
Yes there are the same.extreme atv rider wrote:ok well i've got 170 miles on 800 now i've burnt two belts playin in mud and hill climbs mudzilla's great for traction not good for stock clutch set up.
You can go with EPI There are a lot of people that like the heelclicker because you can adjust them to your needs.
You may want to sign up here and got to the heelclicker section and ask questions.
http://atvquadsquad.com/eve
- extreme atv rider
do both work with the ebs? and chadd whats the deal with the rear brake pedal it never wants to work going down steep hills suck usein the hand brake. i've bled the rear and it never stiffens my buddies is the same way any suggestion?
Try this pump up the rear brake peddle and set a brick or large rock on it overnight. Then the next day try and bleed a little more. I think it is something about the seals need to take a set?extreme atv rider wrote: whats the deal with the rear brake pedal it never wants to work going down steep hills suck usein the hand brake. i've bled the rear and it never stiffens my buddies is the same way any suggestion?
- extreme atv rider
Hope this works for your brakes it works for others.extreme atv rider wrote:ok mr bill i'll give it a wirl see what happens
As for the heel clicker..
With the new weights you only need to remove the six bolt cover on the drive clutch to get to the weights and the spring. Start with the white spring that comes with the kit. then later you can get other springs for different ingagement RPM. join up to the web page i listed and you get a good discount. You get the kits from COB on that other page.
Besure to mark the clocking of the cover this is balanced I also number the bolts so they go back where they were. Use a little blue loctite on the bolts.
Heres more on the rear brake
http://atvquadsquad.com/eve/forums/a/tp ... 3051092623
- extreme atv rider
THANKS to Mr. Bill checked out atvquadsquad got me hc kit comin great price 176.50 includin shippin . those guys over there have great forums alot like these lots of help.....
- extreme atv rider
sure did brake works great for now it's been so hot and i've been workin so i haven't had lot of time too ride. i'm going this wekend so we'll see what happens
Users browsing this forum: No registered users and 94 guests
