Hawkeye Tech Tips
- ACLakey
Hawkeye Tech Tips
Kendo and others, do you have a link for Hawkeye tech tips? Looking for clutching info, carb info, max tire size ect. Thanks.
Lemme see what I can dig up as far as links. I did wind up getting a ton of info on the atvconnection forum, just did a search for Hawkeye. There's a guy on there named Ricky something or another that has done some extensive testing and tuning on his.
I drilled the slide, did a dynojet kit and new lighter (12 gram) clutch rollers on my wife's. Made a big difference. I think the clutch rollers being the biggest.
We had a minor issue at elevation the first time out, after the mods, that I can only attribute to something being in the carb (piece of dirt etc) or a flooding issue. We rode over 50 miles the next day without a hiccup.
Still a little light on power, but it's a 300, you can't expect it to have gobs of grunt. The worst was some of the uphills at 7000+ feet, where she could only muster about 17-18 MPH. However, I maxxed out at 30 on the same hill on my 700. So, it is what it is.
I haven't forgotten about the manual, I just keep forgetting to grab it from the shop and burn that copy.
Here's a discussion mainly about the clutch rollers:
http://forums.atvconnection.com/message ... d1=hawkeye
Another about various mods that different people have tried:
Some guys are using this versus drilling the air box (a TSB put out by Poo):
http://www.thunderproducts.com/tpi_valve.htm
Couldn't find the pics of the carb slide mod, but it's pretty easy. If you remove the slide from the carb, via the top, turn it over and look, you will see a hole in the bottom. On the opposite side of the slide, there is a small divit where you drill the other hole. It'll be practically a mirror image of the 'stock' hole. I used a 3/32 bit because it was the closest thing I had. It's probably a letter bit or maybe even metric. I think that 3/32 is close enogh though, just match up your bit to the stock hole.
Between that, the clutch roller wiehgts (huge difference) and rejetting, I think your Dad will notice a big difference. I'm looking at one of those TPI valves because it'll be much easier to adjust for altitude versus trying different jets.
Still need to get that manual out to you....
Figured I'd give you another update. I put my old 25" Goodyears and steel rims on her Hawkeye. Had to do some minor trimming on the front of the rear wheel fender flares, but they fit great! Way more ground clearance and the ride is much better. Power loss is negligible. We're going riding this weekend to try it out.
Users browsing this forum: Google [Bot] and 36 guests
