05' Sportsman 800 problems.
So I went riding all day yesterday with no problems. Prior to loading up the quad I took about a 15 minute break. When I went to load it up, its started fine, idled rough and low at about 950-875RPM and would die out when throttle was given. I used the winch to get it back into the truck and drove home about 20 minutes away. I tried starting it to unload it, and it worked perfectly. I road it for about 10 minutes and the symptoms did not return. Also at no time did the check engine light come on.
Symptoms:
Rough Idle
Low Idle 950-875 RPM
Stalls Out with Throttle.
(Starts Fine)
It worked fine today also. I just dont want this happening again 25 miles into ride.
Any ideas would be appreciated. Thanks!!
Symptoms:
Rough Idle
(Starts Fine)
- ATV'er
Couple of questions:
Does it have EFI?
Is the air filter clean?- I have had a rough idle due to very dirty air filter.
How much fuel was in the tank?- I have had low fuel and it would not do anything except idle very rough. Fixed it when I added fuel to it.
There are a few other possiblitys but its just a start
Does it have EFI?
If you have EFI...use a Foam UNI filter...not K&N.
I do not know about just spraying in to there.(you know running in to motor?)Ukau wrote:No, but I will be. Gonna do a complete tune up prior to my next ride. Is throttle body cleaner ok to use?
I would take the T-body and remove both clamps.
Turn it so you can see down in to it.
Clean out inside with Q-tips and try not to break the T-cable.
If you can set a bunch or rags under the T-body and then spray with the drippings falling to the rags.
Polaris EFI and K&N =
- wellzy
i don't know if you have this in america but we use REDEX which is a liquid that you add to the petrol which dissolves any rubbish in the fuel system and cleans it. it will make your quad run a little poorly the first few hours but it has massive benifits. i used some in my petrol and have noticed a massive improvment in the running.
SPORTSMAN 850
