2003 Polaris Sportsman 700 Twin
MrBill
Postby MrBill » Sun Feb 08, 2009 11:07 am
jack whelen wrote:You could probably bypass the wheel sensor with a jumper wire then spin the front right tire to see if needle moves @ speedo.
Sorry jack jumping will only read zero on the pod. it sends a pulse at each rev. or a number ofpulses per rev. of the front wheel.
One wire powers the sender the other sends a pulse back. You would need a signal generator at 5 volts peek if I remember right?
CG got your PM
CuriousG
Postby CuriousG » Sat Feb 14, 2009 5:28 pm
Just to compare prices could someone tell me how much I can buy a fan switch for a 2003 Sportsman 700? Here they want $120us.
jack whelen
ATV Obsession Rider
Postby jack whelen » Sat Feb 14, 2009 7:34 pm
Montana Jack
CuriousG
Tranny
Postby CuriousG » Tue Mar 17, 2009 5:15 pm
Ok here goes...its a two part question.
First off. Is it normal that when coming down a gravel hill for the engine braking to slide dangerously down the hill if going fast enough?
Second one is...where on earth do I check the tranny fluid on this thing?
PS: MrBill...could you send me the fluids maintenance part of the manual? THanks again guys!!!
MrBill
Postby MrBill » Tue Mar 17, 2009 5:26 pm
First thing in the morn. :wink: A couple more emails you will have the hole thing :wink:
I think jack can speak for the back wheels locking up when going down hill.
Most of us use high for going down hill.
It a Poo Poo thing. :D
There is a fill plug on the side of the trans. It should say "fill"
You know you are hosting a ride if we all make it to costa Rica
CuriousG
Postby CuriousG » Tue Mar 17, 2009 5:33 pm
Obviously!
There is a group of around 20 or so that usually go over the mountains near my home to the Panama border. The trip is usually 3 days with stops along the way at some incredible beaches. Quads are street legal here in Costa Rica!
Postby Ken » Wed Mar 18, 2009 10:04 am
Yes...that's normal. The engine brake is only the rear wheels..so if they lock up...it will get squirly.
Tip...no matter how steep...use High...and tap gas if it gets goofy.
Tranny....It's mid way...on the RIGHT side (if you were sitting on it). There's a drain, and a fill plug....almost inline with engine drain...just toward right side.
CuriousG
Postby CuriousG » Wed Mar 18, 2009 10:30 am
Why does it appear that on the rear brakes there is only lines running to the right side and the left side appears to not even have a brake?
MrBill
Postby MrBill » Wed Mar 18, 2009 2:17 pm
Do to the full time locked rear diff. You only need a brake on one side.
Users browsing this forum: No registered users and 70 guests
