Just changed all the fluids
Alright just hit the 20hr mark and changed the fluids in the engine, tranny and both front-rear diffs. Diff fluids were nasty along with the trans.You could see the "glitter" as it poured out. The front diff drain plug is magnetic and was covered in crap. Engine oil was dirty but there were no signs of glitter or shavings. Going to do another change at 40hrs.(used Polaris fluids throughout) Just a heads up for anyone on a new machine.
BC.
BC.
- Rogue
As far as I know, all the ATVs come with the factory recommended fluids. I changed several brand new sportsmans, trail bosses, and a pred, and they all had the Polaris Synthetic in them. Except for the Pred, which has a different oil due to the wet clutch, but you can still tell it's polaris factory due to the green color (if it's not completely sooted).
[url=http://www.nvatr.com]North Valley All Terrain Riders[/url]
The definition of irony: working on a Navy base in the middle of a desert.
That's it......but you can still tell it's polaris factory due to the green color
- rangertom
Dang! That worries me too! I took mine in for it's first service at the recommended mileage. I don't imagine the dif fluids were changed, I think I better do that! I guess I'll pick up some of those fluids on the way home. I did oil changes on mine about 15 hours ago, and the oil looked good, it had about 60 hours on it, no shavings. Hopefully I'll find the same when I change out the dif's.
Great info, Thanks!
Great info, Thanks!
05 Magnum 330 4WD (wife's)
04 Sportsman 700 EFI (mine)
Ranger, Friend of mine just bought an 04 700EFI over the holidays..I went with him to pick it up and the guy that sold it says.. Dont worry about a thing till spring our guys went over it.. Well, we get it home and three of us start going over it. Had to fill the battery, fill the brake fluid, the front/rear diff fluids needed to be changed along with the engine oil. We usually get together when one of our machines needs to be serviced (good excuse to drink a few beers) Don't take the dealerships word for it. NO CHADD I'M NOT SAYING YOUR ALL BAD LOLOL. Just that if I do it then I know its done.Dang! That worries me too! I took mine in for it's first service at the recommended mileage. I don't imagine the dif fluids were changed, I think I better do that! I guess I'll pick up some of those fluids on the way home.
Bear
Most of them are full of sh!t....... Just like when they advertise a used sled/quad/car as new or in excellent condition (maybe if your from Lithuania or Botswana) otherwise it's ready for the sh!t pile. lol.....
- rangertom
This whole thing prompted me to take a look at my service manual last night to see the recommended intervals and fluid types required/recommended by polaris. Dayam!!! That's a LOT of different fluids! I kinda figured the diffs would be the same as the Trans...but NOPE! I didn't really think, either, there was an interval called out for cleaning the clutches! I've really been lax about maintainence! I guess I've got some work to do and some $$$ to spend on stuff to keep the machine in order!
At least I've got a grease gun for all the zirks I found in the manual...that's one expense I won't have to come out of pocket for.
This is going to be a busy Friday! at the very least...I'll know my machine and it's status a LOT better!
- Rogue
How many of you guys run the Polaris oil, and how many have switched to something different?
I'm just curious how it seems to be holding up for the riding you guys do.
I find it amusing that Polaris motors have it stamped right on the engine to run 10-40, yet Polaris recommends 0-40.... I think they've been in Minnesota too long...
I switched out all my fluids the other week and used Polaris oils, which I am sure is as good as any other, but did not want to risk anything and what is an additional 10 bones when it comes to such a expensive piece of equiment.
I did have a bitch of a time getting the tranny oil into the hole as it is not the easist to get in there. Any one have some suggestions on how to get it in there without spillingit all over the ground, and then how to make sure that I have enough in there. nothing would be worst than not getting enough.
Use one of those Nozzle type caps Bill is talking about and slide a short piece of hose over it,as long as the hose doesn't plug up the "fill hole" in the tranny you'll know right away when its up to the proper level. I used a short piece of clear gas line.Any one have some suggestions on how to get it in there without spillingit all over the ground
Users browsing this forum: No registered users and 51 guests
