Sportsman 700 problem?
I have an `05 sportsman 700 carbed and am wondering if anyone has had this issue. When new (5 months ago...it was a left over), it cranked off the line and got up to speed pretty quickly. This past weekend I noticed that top speed was only in the high 50's and it felt sluggish. It had all the power/torque to get out of the mud, but felt like it took it's sweet old time getting to higher speeds and didn't have that "snap" off the line.
It's never been under (water in the air box) and the air filter is relatively clean.
It starts and idles fine, so I'm ruling out the spark plugs, and the air filter is clean... no mud, minimal dust. I did plow some heavy snow this winter, and am thinking I might have glazed/smoked the belt...hence the power issues.
Has anyone had this same problem, and if so, what was wrong?
It has low miles (under 200), but I'm thinking of changing the bet anyways.
And what are your top speeds?
Thanks for the help!
High 50's? Never gone that fast...I don't think. Problem is....mainly...we live in the mountains...so rarely is the road perfectly flat for enough distance to see how fast it goes (without gravity assist).
That said.....I'm not sure if the belt would affect top speed. When my belt got trashed from a spring breaking...it mainly affected when the belt engaged....once it engaged, I don't recall any speed issues.
If the engine has lost the "roar" factor...personally..I would still look at Carb or even exhaust issues. If it's bound up....that would slow it down too.
Try running it without a filter too....that would completely eliminate that.
Take it out for a run in high and run it up to top speed. Stop and put your hand on the clutch cover if it is hot most likely you are slipping the belt.
You may need a new belt. I know with my 2004.5 500Ho it has a life time belt warranty, if this is true for yours you may want to call your dealer. I don't think they will pay the labor to change it but exchange your belt.
I have over 600 miles on my first belt(see my latest post lol) Anyhow I can get it to 70mph on a flat gravel road,65 to 70 takes a bit. Does your machine engage right away,just above idle? or does it take a couple hundred rpm before it engages?...Thats what my friends 700 was doing just before the belt "let-go" The use of high/low range is damn important on belt life so I have learned. Also I just changed the plugs, and this is gonna sound stupid, When I changed them I'm sure I could have removed the originals without using a wrench..they were barly snugged up. Every time I stood on the throttle there would be one point were it would misfire for a split second, after the plug change..no more misfire.
If the belt is glazed that might be your problem It may not be worn but the edge is "burnt" causing it to slip..Rule of thumb-Plough Snow In Low. I have ploughed the neighborhood driveways this year(all in low) and still only show minimal wear. About .020'' from new.
05 700 EFI.
BC.
05 700 EFI.
BC.
Well, I took the clutch cover off last night and the belt is in mint condition...no hour glassing, no glaze and there’s no brunt rubber. The belt sits nice and high on the rear, and looking at the shine on the inside of the front clutch, the belt is traveling all the way to the top. There’s no water or dirt inside... it's so clean I could eat off of it!
I then looked at the throttle cable to make sure it was at max range, and it was. The air box is as clean as a whistle. So, I'm at wits end... no freggin clue!
If anyone has any other ideas, let me know.
Thanks.
Thanks.
Ever taken a carb apart??....one tiny bit of crud can ruin your whole day.
Plus, and this is off-topic here but check/change ALL your fluids. I had changed all mine after 20~25 hrs and found "glitter" plus some sludge, only a recomendation as I run the same machine you do.
Take the belt off and clean the clutch sheaves with a scotch brite pad or light emory cloth. You basicly want to rough up the clutches little bit. Also since you have the belt off you can look at the wights and make sure there is no flats spots in them.. More importantly don't use any lube or cleaner (Carb cleaner) on the clutches it will soak into the sheaves and cause you belt to slip. Also do you have stock size tires?? And air pressure will afect top speed.. I can get my 05 700 efi to 65 mph with no problems.
Chadd wrote:to 65 mph with no problems.
With no problems.....and 10% downhill grade and a 20mph tailwind.
Chadd wrote:Flat ground, ie hwy 49....
LOL....I've been trying to......forget.
Remember it well...it will never happen again.
I actually was talking to Roger about it when he picked up the tires....he said we should have turned RIGHT , where he busted us....and gone over the OTHER bridge that's not used as much.
Oh well.
Oh well.
or faster..... Like maximum velosity while tumbling down a hill.I can get my 05 700 efi to 65 mph with no problems.
Users browsing this forum: No registered users and 66 guests
