Warn Winch
- Wears Teal Eddie Bauer clothes
Warn Winch
hey does anyone know how to instal a 3000 warn winch on a 2005 polaris 700. if you could send some pictures of wear you mounted the silanoid, remote adapter, and of the winch mounting bracket itself i would appreciate it. Thanks, Kyle
Chadd or Dusty will chime in for location.
For the wiring and service check here. http://www.atvobsession.com/manuals/sportsman_800.pdf
I installed a ramsey 3000 in my 2005 800, but they are basically the same frame. . .
I put the selenoid under the right side near the gas thank. there is a small tray like thing that that I was able to mount it to. When I get home this weekend will take a picture or two for you and show you what I did. . .
mine was pre-wiried with the leads from the batery. the leads went form the battery, along the frame to a spot just under the pod (under the plastic cover behind the storage box. This is one of the reasons why I mounted it where I did.
Users browsing this forum: No registered users and 47 guests
