ITP Type 7 Beadlocks
- ATV'er
Well I finally decided to take the plunge and buy beadlocks. Figured I could run the lower pressure if I wanted and did not have to worry as much.
Here they are instaled.
Up Close
Ok, I decided to do some playing around. I aired down to 1.5 - 2.0 lbs of pressure. Here are some random pictures.
Up Close
scott those look SICK!!! wow i can't wait to see how they work on the trail if you don't mind sharing how much were they?
p.s. my atv is still in my buddy's shop getting skid plates and bumbers and tubes as soon as its done we need to get out and RIDE!!
- ATV'er
The trail is called, my work.
The rims I got from OTD here in Auburn. With the 15% atvobsession discount they were $160.00 per wheel before taxes.
- Aka: Fishoil
Not rain on anyone's..
Going with just the outside bead locks?
I have the first of SS 108's OMF'ed true bead locks with no troubles and I hear that you and Ken have blown inside's on stock or reg rims.
Where will be the big change with these?
- ATV'er
I have never had much of a problem until recent with popping beads. When I had the 589's and the stock tires I would pop the bead off about once a year while doing snow rides. When I popped them off I was usally riding in ruts with the quad was at about a 45 angle and I would get snow between the rim and the tire. I would slowly get snow in the bead and it would start to leak.
More recently when I took off the 589's to install the bighorns I had some rubber on the rim so I had the bright idea of taking a wire wheel to the rim which ended up to be a big mistake. After that I could not get the tires to hold air even with super high pressures. I ended up putting slime in the tires to help hold air in them. After that I had flats all the time and was popping tires off.
I believe most of all my flats begun from getting some thing between the outter rim and tire. Once I lost the bead on the out side I then lost the inside. My real answer for popping tires off in the winter is to buy tracks next fall.
Users browsing this forum: No registered users and 111 guests
