back fire, no power, idles good ?
King of Quads
auendave
Postby auendave » Sun Jul 01, 2012 12:28 pm
I ran my quad through a creek a couple weeks ago, I hit a deep spot when I got to the othert side the quad started backfiring and no power, yesterday I started and it seemed fine I rode down a hill and then when I started back up same as before no power backfire, I changer the spark plug and it was black, so does this mean it is the carb? all help appreciated
Paynes creek 2013
Re: back fire, no power, idles good ?
Postby hemingray » Sun Jul 01, 2012 8:26 pm
Water in the spark coil? When one of the coil packs on my truck cracked and started getting some water in it, it would idle but miss under power. Wonder if you got some water in somewhere that's stuck around. The black on the plug could simply be from the misfiring?
EigerMike
Postby EigerMike » Mon Jul 02, 2012 5:19 pm
dave, take the carb off clean out the bowl and jets then check your vent tube under the seat make sure it isnt kinked or pluged.allso put a inline fillter onj it.try that and a new spark plug .028/.031 gap. if that doesnt work need to try a cdi off another quad .you can allso unplug a few wires and make sure they are dry
EigerMike
Postby EigerMike » Mon Jul 02, 2012 5:21 pm
allso check for air leakes on the intake of carb
auendave
Postby auendave » Mon Jul 02, 2012 9:26 pm
I see I will be busy on the fourth thanks for all the input
dave
Paynes creek 2013
auendave
Postby auendave » Sat Jul 14, 2012 6:50 pm
finally got it done. rebuilt carb it was so dirty from backfire or what ever, took coil and all wires apart and dried them, put all back together and it seems to run all right, so now I have to take it out for a real tryout, up a few hills and a good run not just down the street in my neighbor hood. thanks for all the help
Paynes creek 2013
Postby hemingray » Sat Jul 14, 2012 8:26 pm
Cool - hope it runs OK in the wild too!
Postby Kendo » Mon Jul 16, 2012 11:29 am
Sometimes what happens on these vacuum diaphragm carbs is when they backfire, it shoots the jet needle up past the seat and it never goes back in the jet. It'll idle fine, because it runs off a different set of jets for that circuit. The problem manifests when you go half to full throttle and it kicks the main jet. With the needle out of it's seat, it just pours fuel in and causes more backfiring and bogging down. Simply taking it apart and putting it back together correctly will usually fix the problem. Sounds like you'll be OK. Cleaning the carb is NEVER a bad idea.
EigerMike
Postby EigerMike » Tue Jul 17, 2012 9:39 pm
right on dave! you ready to go camping now?
Users browsing this forum: No registered users and 72 guests
